Headphone Jack as additional output
Hello, I am reviving this old topic to ask if this is the same case for MOD Dwarf. I just received it and playing with it little bit and separate headphone output is truly missing if someone want to use this for live or recoding in-ear monitoring. It would bring a lot of possibilities like having click in ears and not sending it to the output. I am able to do that now but click is in one ear only and I can use one output only. Example with two instruments above that you need to have each one separately in each ear to keep outputs separately is also valid for live. Or I would might to want use cab sim for headphones but not output because it goes to separate amp. And so on…
