Hardware Bypass Plugin Automatic turns to on
Description
The Hardware Bypass Plugin, in a Saved Pedalboard, when you call the pedalboard, even if the initial value is OFF, it changes automatically turn the Bypass ON.
Some other plugins have the same problem, and just reponds (on / off) after 2 or 3 times pressing.
How to reproduce
Create a Pedalboard.
INclude the Hardware Bypass Plugin
Assign it to the Control Chain --> FootEx.Foot#(1 to 4)
Turn the Bypass OFF
Save the Pedalboart.
Call another pedalboard.
Call the previous saved pedalboard, and the Bypass will be ON. Even if you press the foot that you assigned, the bypass still in ON. After tree press on the pedalboard, the Bypass starts to repond.
By the way, in all pedalboards that I assigned any Foot#, it seems the control do not function correctly ultil 3 times press.
Expected/suggested solution
The footswitch responds immediatelly after you press it.
Additional information
Open the controller menu (hold left knob down), navigate to Info > Versions and write down here the versions.
  • release: V1.9.1
    Restore: 29C3BBA
    System: 29C3BBA
  • controller: 8403942
    ControlChain FootEx V0.2.2
  • Operating system: (Mac)
  • System version: (Mac 10.14.6)
This sounds similar to the bug I reported some time ago:
