Guitarix team
An analogue simulation of the Vintage Fuzz Master (Devi Ever). This one comes with a bass/bright switch and is a bit modified to produce less volume then the original pedal. With "intensity" down it will blow up the low end, but turn it up and it produce the well known and loved octave up artifacts.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2d1aXRhcml4LnNvdXJjZWZvcmdlLm5ldC9wbHVnaW5zL2d4X3ZmbV8jX3ZmbV8=
