GxScreamingBird - MOD Devices
Guitarix team
Emulation of the Electro-Harmonix Screaming Bird treble booster (*) (*) 'Other product names modeled in this software are trademarks of their respective companies that do not endorse and are not associated or affiliated with MOD. Electro-Harmonix Screaming Bird is a trademark or trade name of another manufacturer and was used merely to identify the product whose sound was reviewed in the creation of this product. All other trademarks are the property of their respective holders.' *Unofficial documentation
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2d1aXRhcml4LnNvdXJjZWZvcmdlLm5ldC9wbHVnaW5zL2d4X3NjcmVhbV8jX3NjcmVhbV8=
Originally designed as a boost pedal that added a lot of treble bite to cut through the mix for a lead riff.
So keep in mind there is a lot of treble so this pedal works really well with heavier bass & mids tone amps like a
Marshal.
This allows you to have a heavier crunch for your rhythms and a bright loud lead line.
Adds a volume boost around 2khz.
