"Flanging /ˈflændʒɪŋ/ is an audio effect produced by mixing two identical signals together, one signal delayed by a small and gradually changing period, usually smaller than 20 milliseconds. This produces a swept comb filter effect: peaks and notches are produced in the resulting frequency spectrum, related to each other in a linear harmonic series. Varying the time delay causes these to sweep up and down the frequency spectrum. A flanger is an effects unit that creates this effect. Part of the output signal is usually fed back to the input (a "re-circulating delay line"), producing a resonance effect which further enhances the intensity of the peaks and troughs. The phase of the fed-back signal is sometimes inverted, producing another variation on the flanging sound." Wikipedia *Unofficial documentation source: http://en.wikipedia.org/wiki/Flanging
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2d1aXRhcml4LnNvdXJjZWZvcmdlLm5ldC9wbHVnaW5zL2d4X2ZsYW5nZXIjX2ZsYW5nZXI=
