Hello,
I have two questions regarding the plugins:
- I can’t find the Guitarix “Metal Head” amp module
- Regarding the “rkr dual flange” plugin, each change of factory presets results in a disconnection.
Is this normal?
Thank you for your answers.
Hello,
what plugin is that? I dont find it on the plugin list, not even in beta.
Certainly not normal. this would be a bug.
When a plugin crashes it brings down the audio host too, which results in that “disconnected” message.
Reloading the page makes the previous session load again. (as a kind of crash-recovery mechanism)
That specific plugin is in beta though, we do not give proper testing on those.
Proceed with caution when using beta plugins.
For the Metalhead plugin:
https://pedalboards.moddevices.com//pedalboards/5b6469e72564d4170c2ee546
so you mean GxCabinet - MOD Devices ?
No, it’s the amp module just after the Tube Screammer drive pedal.
ah you are right.
this plugin is now completely missing.
need to ping the developer, it was either intentional or a mistake on our side.
@brummer any ideas?
falkTX,
thank you for your answers.
When I remember right, I’ve ask once @jesse to remove the Metalhead, as it wasn’t a good plug.
