A pedalboard to convert the guitar sound into more bass sounds, not perfect though, depends on the guitar you're using, for you to adjust ;) I'm using a semi-hollow body for this one. As there are thousands of bass sounds and styles to create, it's difficult to know you're going to like it, but I linked both footwitches to so you can add a little crunch or treble right away... Have fun!
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com//pedalboards/5c26974d2564d433e8ba2e04
