Thought to be use in a DI recording context, this dual amp configuration has practically the same configuration. A compressor on one side, a tube screamer on the other. The EQs on each amps have been adjusted to produce a better definition of the notes of a chord, to enhance clarity to each guitar pickups selections, add some warmth to the sound. Plus a touch of reverb to emulate different rooms will help to slightly broaden out the sound of the instrument. Finally, why don't use this setup by re-amping a track in your home studio? Style: DI recording, Re-amping, Blues lead, funk grooves
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/pedalboards/5aeaa1992564d449773a185f
