Gossiper - Plugin to say what is happening when you are looking it
This plugin is killer !!!
I have a few requests though :
  • could a footswitch trigger be triggered by a physical footswitch AND by another trigger inside the plugin ? (and this other internal trigger footswitch 1 could be assigned with midi)
    So, in this case, the physical footswith would change state as usual AND with midi ?
  • if you find a way to change the popup message, would it be possible to assign a midi expression pedal to the Pot 1 and then showing the value of this pot changing in a popup ?
    (as I asked here Expression pedal : showing percentage on the screen)
I don’t know any plugin doing this but the Looperlative LP3s. If not giving the source code for this maybe @looperlative could help with this ?
(changing the text of a popup message)
