I’m learning about max/gen to pickup plugin knowledge. Initial idea is to create a kill switch pedal (momentary) - I would need a midi pedal controller to control that.
Is that thing possible with gen?
I didn’t really get the question? If it’s possible to use MIDI in Gen?
Yes - control a gen plugin via midi controller plugged into usb-host I guess it is okay as I’ve used midi learn on other plugins that I think came from gen
you can control pretty much any regular plugin parameter with MIDI CC or pitchbend through the MIDI learn function.
the gen~ generated plugins are no different.
Thanks for confirming
