So far I’m using external volume pedals which the Mod plugs on. However with the Mod Duo X I thought I would experiment changing volume through the knobs.
So I’m putting the Mod Gain effect, its gain goes for -40dB to 40dB, and link the knob to it (later I thought the Mod volume pedal would control that).
What I noticed is that it does not get to full silence, if I have a loop playing at -40dB I still hear it leak.
So… maybe I could add an effect on the output that kills anything which is very low, or switch to the TinyGain pedal and click for the mute: but it does not seem optimal.
I was wondering:
- what set-up people use for the volume pedal ? assuming you are in fade-out to silence
- do you know of an effect that continuously goes from + dB to full silence ?
thanks
