Gain 2x2 - MOD Devices
MOD Team
Stereo version of the simple volume gain plugin without "zipping" noise while messing with the gain parameter.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL21vZGRldmljZXMuY29tL3BsdWdpbnMvbW9kLWRldmVsL0dhaW4yeDI=
Hello Mod developers,
I use this Stereo Gain plugin adjusting volume quite a lot, but it would be quite useful to me and others if it had another coarse parameter range, maybe from -infinity to +3dB or +6dB. I seldom have to boost gain up to 40dB if the incoming signal has the correct gain, but I like to cut signals more often in a snapshot.
Then I can adjust the gain more precisely when I assign it to an encoder range.
I could imagine that the range could be switchable, but assigning it to an encoder makes it customizable for itself…
