Gaffa - MOD Devices
SHIRO Plugins
The SHIRO Gaffa is a very characterful delay. It doesn't perfectly replicate your input like digital delays do, but instead it explores the irregularities, quirks and sound coloring of analog tape delays. The Gaffa has the more straightforward delay controls such as MIX, LOWCUT, REPEATS and TIME. On top of that, there are controls such as BIAS, CRINKLE, DRIFT, WOWFLUTTER and TAPEAGE that allow you to configure each aspect of your perfect tape delay sound. The cherry on top is the TRAILS switch. This switch sets whether the plugin ON/OFF switch bypasses the input, or the output of the plugin. With the TRAILS enabled, this results in the effected sound peacefully dying out when you bypass the plugin. Features: Modeled by SHIRO
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/dXJuOm1heGdlbjpnYWZmYQ==
The plugin i’ve been waiting for thank you Shiro
Can you go into more detail about the
Bias
Crinkle knobs.
Thanks for creating this awesome sounding delay! is there a way to sync the delay time to the device time?
I didn’t see a way to sync it to the global tap tempo on a Dwarf. However, it looks like there is a global MIDI sync feature, but I haven’t tried it.
