Is it possible (or if not ,will it be one day…) to replace fx or synth by another without recabling…?
It can be useful when you try differents fx or synths…( just put the new fx “on” the other , wait maybe 2 seconds ) and if it has the same in and out , it will be replaced by the new one…
Maybe there’s already a way to do that…?
Thanks
This makes total sense.
Either exactly what you described or a different way to swap between plugins without recabling will eventually be needed.
I’m saving your suggestion as a request. No promises when we will have time to work on that, but we will keep an eye on it.
Thanks
+1 on this one ! just like CTRL+ALT+V in Max/MSP.
+1 for this.
A dropover zone on plugins, followed by a confirmation window where you can remap previous plugin inputs and outputs tto new plugin inputs and outputs should be feasible, and would cover all cases, not only those where in/out numbers match
