they might be busy with something else, the delay in response is like 2 to 3 days
also it might be useful for others with similar issues. anyway, here is the dmesg output:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.38-modduo (builder@57f7c2f6381c) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0)) #10 SMP PREEMPT Wed May 27 02:30:00 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: MOD Duo
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 262144
[ 0.000000] Normal zone: 1536 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 65536 pages, LIFO batch:15
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] percpu: Embedded 15 pages/cpu s29120 r8192 d24128 u61440
[ 0.000000] pcpu-alloc: s29120 r8192 d24128 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260608
[ 0.000000] Kernel command line: earlyprintk=ttyS0,115200 console=ttyS0,115200 loglevel=9 panic=0 mod_restore=ssh
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 914760K/1048576K available (5027K kernel code, 198K rwdata, 1136K rodata, 18432K init, 287K bss, 35512K reserved, 98304K cma-reserved, 262144K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x2d0/0x458 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000021] Switching to timer-based delay loop, resolution 41ns
[ 0.000481] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000810] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns
[ 0.001020] Console: colour dummy device 80x30
[ 0.001074] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.001090] pid_max: default: 32768 minimum: 301
[ 0.001247] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001264] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002074] CPU: Testing write buffer coherency: ok
[ 0.002532] CPU0: update cpu_capacity 1024
[ 0.002549] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.060053] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.080020] rcu: Hierarchical SRCU implementation.
[ 0.120088] smp: Bringing up secondary CPUs ...
[ 0.210590] CPU1: update cpu_capacity 1024
[ 0.210600] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.210751] smp: Brought up 1 node, 2 CPUs
[ 0.210770] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.210777] CPU: All CPU(s) started in HYP mode.
[ 0.210782] CPU: Virtualization extensions available.
[ 0.211544] devtmpfs: initialized
[ 0.218315] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[ 0.218637] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.218668] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.222152] pinctrl core: initialized pinctrl subsystem
[ 0.222915] NET: Registered protocol family 16
[ 0.231558] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.249784] SCSI subsystem initialized
[ 0.249992] usbcore: registered new interface driver usbfs
[ 0.250045] usbcore: registered new interface driver hub
[ 0.250190] usbcore: registered new device driver usb
[ 0.251533] clocksource: Switched to clocksource arch_sys_counter
[ 0.251925] FS-Cache: Loaded
[ 0.252142] CacheFiles: Loaded
[ 0.258621] NET: Registered protocol family 2
[ 0.259319] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.259354] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.259445] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.259572] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.259716] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.259782] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.260032] NET: Registered protocol family 1
[ 1.459055] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ 1.464850] fuse: init (API version 7.31)
[ 1.465630] bounce: pool size: 64 pages
[ 1.465688] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.465700] io scheduler mq-deadline registered
[ 1.465708] io scheduler kyber registered
[ 1.466461] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 1.469868] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 1.479022] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 1.480566] sun4i-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 1.481073] printk: console [ttyS0] disabled
[ 1.501375] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 45, base_baud = 1500000) is a U6_16550A
[ 2.053604] printk: console [ttyS0] enabled
[ 2.058283] sun4i-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pi not found, using dummy regulator
[ 2.088567] 1c28800.serial: ttyS1 at MMIO 0x1c28800 (irq = 46, base_baud = 1500000) is a U6_16550A
[ 2.097940] sun4i-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-ph not found, using dummy regulator
[ 2.128107] 1c29000.serial: ttyS2 at MMIO 0x1c29000 (irq = 47, base_baud = 1500000) is a U6_16550A
[ 2.157977] 1c29400.serial: ttyS3 at MMIO 0x1c29400 (irq = 48, base_baud = 1500000) is a U6_16550A
[ 2.169662] loop: module loaded
[ 2.173523] sun4i-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 2.184275] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0x64
[ 2.190629] nand: Micron MT29F64G08CBABAWP
[ 2.194765] nand: 8192 MiB, MLC, erase size: 2048 KiB, page size: 8192, OOB size: 744
[ 2.203705] Bad block table found at page 1048320, version 0x01
[ 2.210082] Bad block table found at page 1048064, version 0x01
[ 2.216278] nand_read_bbt: bad block at 0x00000b400000
[ 2.221411] nand_read_bbt: bad block at 0x00000b600000
[ 2.232515] 9 fixed-partitions partitions found on MTD device 1c03000.nand-controller
[ 2.240350] Creating 9 MTD partitions on "1c03000.nand-controller":
[ 2.246665] 0x000000000000-0x000001000000 : "bootfiles"
[ 2.262182] 0x000001000000-0x000002800000 : "restore"
[ 2.272209] 0x000002800000-0x000002e00000 : "kernel"
[ 2.282164] 0x000002e00000-0x000003000000 : "dtb"
[ 2.302047] 0x000003000000-0x000004800000 : "restore-backup"
[ 2.308717] 0x000004800000-0x000004e00000 : "kernel-backup"
[ 2.322107] 0x000004e00000-0x000005000000 : "dtb-backup"
[ 2.332141] 0x000005000000-0x000045000000 : "system"
[ 2.352089] 0x000045000000-0x000145000000 : "data"
[ 2.359357] libphy: Fixed MDIO Bus: probed
[ 2.363550] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.370072] ehci-platform: EHCI generic platform driver
[ 2.375836] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.382061] ohci-platform: OHCI generic platform driver
[ 2.387731] usbcore: registered new interface driver usb-storage
[ 2.394090] i2c /dev entries driver
[ 2.398493] axp20x-i2c 0-0034: AXP20x variant AXP209 found
[ 2.410836] axp20x-gpio axp20x-gpio: DMA mask not set
[ 2.417636] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
[ 2.425322] ldo1: supplied by regulator-dummy
[ 2.429882] ldo2: supplied by regulator-dummy
[ 2.435326] ldo3: supplied by regulator-dummy
[ 2.440257] ldo4: supplied by regulator-dummy
[ 2.444791] ldo5: supplied by regulator-dummy
[ 2.449714] dcdc2: supplied by regulator-dummy
[ 2.454796] dcdc3: supplied by regulator-dummy
[ 2.459681] vdd-int-dll: Bringing 1250000uV into 1300000-1300000uV
[ 2.466900] axp20x-i2c 0-0034: AXP20X driver loaded
[ 2.473580] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[ 2.481203] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 2.489879] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.496253] NET: Registered protocol family 17
[ 2.500791] ThumbEE CPU extension supported.
[ 2.505105] Registering SWP/SWPB emulation handler
[ 2.514193] ehci-platform 1c14000.usb: EHCI Host Controller
[ 2.519805] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[ 2.538323] ehci-platform 1c14000.usb: irq 32, io mem 0x01c14000
[ 2.571574] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[ 2.577936] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.586236] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.593469] usb usb1: Product: EHCI Host Controller
[ 2.598343] usb usb1: Manufacturer: Linux 5.4.38-modduo ehci_hcd
[ 2.604357] usb usb1: SerialNumber: 1c14000.usb
[ 2.609572] hub 1-0:1.0: USB hub found
[ 2.613403] hub 1-0:1.0: 1 port detected
[ 2.617961] ehci-platform 1c1c000.usb: EHCI Host Controller
[ 2.623614] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[ 2.631692] ehci-platform 1c1c000.usb: irq 35, io mem 0x01c1c000
[ 2.661566] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[ 2.667879] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.676169] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.683399] usb usb2: Product: EHCI Host Controller
[ 2.688273] usb usb2: Manufacturer: Linux 5.4.38-modduo ehci_hcd
[ 2.694288] usb usb2: SerialNumber: 1c1c000.usb
[ 2.699384] hub 2-0:1.0: USB hub found
[ 2.703208] hub 2-0:1.0: 1 port detected
[ 2.707744] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[ 2.714433] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
[ 2.722592] ohci-platform 1c14400.usb: irq 33, io mem 0x01c14400
[ 2.795757] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[ 2.804051] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.811266] usb usb3: Product: Generic Platform OHCI controller
[ 2.817198] usb usb3: Manufacturer: Linux 5.4.38-modduo ohci_hcd
[ 2.823212] usb usb3: SerialNumber: 1c14400.usb
[ 2.828353] hub 3-0:1.0: USB hub found
[ 2.832180] hub 3-0:1.0: 1 port detected
[ 2.836721] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[ 2.843411] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
[ 2.851357] ohci-platform 1c1c400.usb: irq 36, io mem 0x01c1c400
[ 2.925750] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[ 2.934039] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.941254] usb usb4: Product: Generic Platform OHCI controller
[ 2.947186] usb usb4: Manufacturer: Linux 5.4.38-modduo ohci_hcd
[ 2.953199] usb usb4: SerialNumber: 1c1c400.usb
[ 2.958307] hub 4-0:1.0: USB hub found
[ 2.962132] hub 4-0:1.0: 1 port detected
[ 2.966735] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 2.998634] Freeing unused kernel memory: 18432K
[ 3.003477] Run /init as init process
[ 3.094949] random: dd: uninitialized urandom read (512 bytes read)
[ 3.225818] random: dnsmasq: uninitialized urandom read (128 bytes read)
[ 3.233080] random: dnsmasq: uninitialized urandom read (48 bytes read)
[ 3.545452] using random self ethernet address
[ 3.550054] using random host ethernet address
[ 3.555586] usb0: HOST MAC ba:05:9e:33:61:1c
[ 3.560087] usb0: MAC a6:e3:26:8f:f8:ab
[ 3.564651] using random self ethernet address
[ 3.569112] using random host ethernet address
[ 3.579984] g_ether gadget: Duo Ethernet, version: Duo
[ 3.585677] g_ether gadget: g_ether ready
[ 4.061005] g_ether gadget: high-speed config #1: CDC Ethernet (ECM)
[ 4.999697] random: crng init done
[ 5.003174] random: 2 urandom warning(s) missed due to ratelimiting
[ 33.121578] vcc3v0: disabling
[ 33.124570] vcc3v3: disabling
[ 33.127535] vcc5v0: disabling
