Fluid SoundFX - MOD Devices
falkTX
This plugin contains the 'Sound FX' section of the Fluid GM soundfont. The Fluid GM soundfont was constructed in part from edited/cleaned/remixed/programmed samples found in the public domain and recordings made by Frank Wen.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2t4c3R1ZGlvLmxpbnV4YXVkaW8ub3JnL3BsdWdpbnMvRmx1aWRQbHVnX0ZsdWlkU291bmRGWA==
