This pedalboard is meant to show the difference between filtered and unfiltered octave-up sounds. Like every instance of adding effects to your sound: consider the mix wisely! 1. unfiltered 2. filtered 3. unfiltered + dry 4. filtered + dry 5. unfiltered + dry 6. filtered + dry
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com//pedalboards/57e3fddc2564d426c6efc96e
