Inspired by That Pedal Show's episode on recreating tape delay, this is a faux tape delay made from individual parts. The delay pedal you see here is doing a single clean delay that is fed back to itself with compression, vibrato and eq filtering. You adjust mix and feedback with the various gain pots.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/pedalboards/5e98e12c2564d41c3e1a9fc5?fbclid=IwAR2HNoiZ5JrdrG6T2q0Lv3nUm_6gGNazkoqXQJWP1-V-X_zBiCcwvgdqdJY
