Hi all,
I am in the process of developing a plugin for use with the mod dwarf. I have the DSP basically working but struggling to get the GUI working in the way I want to.
I have used the modspectre plugin as a source example for sending data from the DSP to the GUI and I can get this basically working, however right now I am passing a small vector of 7 floats from the DSP code to the GUI and then using the index in that array to identify what each float means.
This works but is not nice, I assumed I could change the vector to a Atom Object instead giving each float (and maybe later some items that are not floats) a key/name.
The relevant bit of code that is working based on modspectre is like:
static void
tx_to_gui (ModBLevelMatch* self, const float* bins, int32_t n_bins)
LV2_Atom_Forge_Frame frame;
lv2_atom_forge_frame_time (&self->forge, 0);
lv2_atom_forge_object (&self->forge, &frame, 0, self->uris.patch_Set);
lv2_atom_forge_key (&self->forge, self->uris.patch_property);
lv2_atom_forge_urid (&self->forge, self->uris.stats);
lv2_atom_forge_key (&self->forge, self->uris.patch_value);
lv2_atom_forge_key (&self->forge, self->uris.stats_vector);
lv2_atom_forge_vector (&self->forge, sizeof (float), self->uris.atom_Float, n_bins, bins);
lv2_atom_forge_pop (&self->forge, &frame);
However I wanted to modify that to something like (but will add extra params later not just floats):
static void
tx_to_gui (ModBLevelMatch* self, float current_gain_db, float input_level_db)
LV2_Atom_Forge_Frame object_frame;
lv2_atom_forge_object (&self->forge, &object_frame, 0, self->uris.stats_object);
lv2_atom_forge_key (&self->forge, self->uris.stats_current_gain_db);
lv2_atom_forge_float (&self->forge, current_gain_db);
lv2_atom_forge_key (&self->forge, self->uris.stats_input_level_db);
lv2_atom_forge_float (&self->forge, input_level_db);
lv2_atom_forge_pop (&self->forge, &object_frame);
However when I make changes as minimal as possible the GUI is just not getting any relevant messages from the DSP. I have been debugging into the javascript websocket onmessage and it seems the backend is just not sending the data (or something wrong).
I have read all related LV2 docs I could find and so far nothing is telling me what might be wrong. My intuition is just telling me maybe a PATCH Set doesnt work with an “object”. Or maybe I need to write an object body somehow without the atom header (If so I cant see any docs on how to do this)?
Part of my conclusion for that is that the following works ok:
static void
tx_to_gui (ModBLevelMatch* self, float current_gain_db)
