Equalization
I would like to know if there is the possibility of copying from a VST plugin and making it LV2, my question is due to the fact that I would like to transfer to the DWARF some adjustments obtained with the Match EQ that I use with Logic.
maybe if you find a similar enough plugin?
the name rings a bell from a plugin I know. anything related to the specs of GitHub - brummer10/MelMatchEQ.lv2: MelMatchEQ is a profiling EQ using a 26 step Mel Frequency Band ?
just great, this will help me for many acoustic instrument jobs. Thanks
Realize that
  1. this is not a VST plugin, but a built in function in Logic (so far as I can see) and
  2. without having source-code to any such functions/plugins there is no way to do a port to anything.
