EQ presets in snapshots
In my main pedalboard, I have different snapshots with different sets of plugin user presets. I noticed that EQ presets don’t change when I switch between snapshots. Other plugins load their presets correctly. I tested with EQs from x42 and RKR.
Has anybody else seen this behaviour?
If not, would anyone care to test? Create two snapshots and two different EQ presets, one for each snap. Use the GUI to switch between snaps. Does the correct EQ preset load?
My Dwarf is running Alabs 11 but I am not saying that that is causing it. I will check with the MOD firmware, just to be sure.
I tried the original firmware. All plugin presets load correctly when changing snaps. Will head over to Alab’s thread and report it there.
Could it be caused by the different granularity the customer firmware provides? Check the Starless documentation, now your can specify the subset of plugins and parameters you want to include into the snapshot.
Hope this solve the issue you’re facing.
