Dear people
I’m new to the forum and also new to the Dwarf mod.
Is there already a digital image of the EHX C9 or another way to conjure up Hammand organ sounds from the mod Dwarf?
best regards
Webbel
Please use the common language on the forum.
Due to the international nature of the MOD project this is English.
Well, depends on the context.
If you wish to generate it with a guitar, it will be a bit complex, stacking CV/synth modules, octavers and filters and such…
Check out this page to see how far “guitarsynths” can go!
If you want to generate them with the press of a key on a keyboard, you can upload “sound font files” to your Dwarf and play them using a midi controler. A sound font is like a text font; a bank of all notes, represented as samples. A keypress represents playing a certain sample
Or use setbfree https://pedalboards.moddevices.com/plugins?text=setbfree&
I find the setBFree consumes too much CPU ( talking about the midi organ, I presume that’s why it stays in the beta store)…
I use a fluidsynth organ and the setBfree leslie plugin.
Actually, with the OBXD synth or the dexed synth you can create reasonably close hammond sounds, and then add a spring reverb, overdrive and the setBfree leslie.
That setup will already sound better then 90% of the allround synths who have a stock hammond sound. (mainly because of the SetBfree leslie emulation is really good, mod has a really good spring reverb convolution loader and alot of overdrives to choose from)
Thank you for the tips. It’s more complicated than expected. I want to create the sounds with the guitar and not with a Midi controller, which is probably quite easy.
