I will fully admit that I am likely missing something that already exists, but here is my question…
Is there a plugin I could use “easily” to blend one effect (like distortion or the Drop plugin) with the clean signal? I know about the ability to run multiple cables out of, and into, a plugin.
I am currently using plugins like “Switchbox” which lets me go from clean signal to a blended signal easily…but my issue with doing that is when using “Switchbox” as the effect on-off switch, then the light on my physical footswitch is always on and always the same color (green). So I don’t know, just by looking, if the effect is on or not.
I am also trying ones like “Stereo X-F” which seems to blend super well, but overall seems to bring the overall volume down when it is blending?
I do know that I can easily use Gain plugins to adjust blends, but that is adding more pedals to the pedalboard. I guess I’m wondering if there is a Plugin similar to a pedal I have a One-Control mosquito blender.
http://www.one-control.com/mosquite-blender-expressio.html
Anyways, I will get things set up in to get what I want, but I was just checking to see if I’m missing something, or if not, I could put an idea out there?
