Edit mod dwarf on ChromeOS?
Just a simple question:
Can I use a Lenoveo N23 Chromebook with an Arm CPU + Chrome OS to edit my Mod dwarf ?
Edit I mean use the browser and connect the unit via USB and edit pedalboards
If you can go to the world wild web with your smartphone-that-looks-like-a-pc I don’t see any thing that could block it
I am asking if the USB on the ChromeBook w/ ChromeOS will recognize the mod dwarf. So it’s not about the internet connectivity you’re pointing out
Oh, sorry !
chomeOS is like android, so I think you’ll have to use WiFi, but not sure. I’ve not been able to connect via USB on my android phone or ereader. Don’t know why since android is a Linux OS
I’ve no problem connecting with my kubuntu PC through USB though
I can confirm, it works.
Can you elaborate?
It works to connect to a MOD unit over USB using a device running ChromeOS ?
Yes exactly, just like a regular PC running Windows: connect the Dwarf to the Chromebook via USB and it works in seconds.
thanks so much
Just to complete the info, I tested on an old Acer CB314.
