Dwarf factory default system restore using image moddwarf-v1.13.3.3259 .tar and instructions from ttps://wiki.mod.audio/wiki/Factory_Reset_Images is stuck on “CHECKING FILE”. I’ve powered down and tried several times with the same result. I had no trouble copying the tar file to the drive on my macbook, and the dwarf finds the drive and the file. But then it just hangs on “CHECKING FILE”.
I was sure I’d seen this addressed on the forum but I can’t find the post.
At this point I think I’ll just ssh in and do it manually if I can find out exactly how to do it. I’ve done it before, just can’t find the instructions. I’ve probably got them printed out somewhere around here. I’m in right now - already had passworldless ssh set up… Keys, known_hosts, etc, so I don’t have to remember the password.
Like I said, no gigs, but even if I did I could just pull out the dwarf and put in the duo.
I’m really screwed now. I’ll try again in a few days and if I absolutely have to I’ll pull the cover and short the pins. I really hate to do that though.
Thanks! I’ll do that today. I’ll just pull the Dwarf off the board, put it on my desk with nothing attached, and start over.
Yesterday was a bad day all around and I was getting more than a little frustrated with everything and it spilled over into my dealings with the dwarf.
Already working on cup of fairly weak “low acid” coffee with soy milk. I dumped the first one. I sound like a real wuss, but TFS. Beats the hell out of another trip to the ER. Or just a trip straight to the morgue, as I suggested last time to the EMS guy who was poking needles into my arm.
“I’m not dead!”
“…you’ll be stone dead in a moment.”
