It’s been a long time since I wrote and I don’t remember. Since with the Program Change the change of the Pedalboards is slow and since I need 5 sounds that differ from each other only have some settings, is it possible to change the snapshots with an external pedal board (program change)? I need not only to turn effects on and off but for some to change parameters as well.
Yes. That is totally doable. You can use program change messages either to change snapshots or pedalboards. Take a look here
Yes, you can. You need to set a different midi channel from that of the pedalboard swithcin. Basically PC through one channel control pedalboard switching and PC throught the other control shapshot switching.
