Nice to have: ability to dim LEDs. They look too bright in some cases.
Saved as request
Still need the ability to dim LEDs !!
- When a tap tempo is assign to a switch we got a amazing white, so the light technician taped my dwarf : not cool
- when a switch is assign to a on/off function, but the LED showing the switch state is read, and doesn’t turn off completely when the switch is in off state. It’s a bit confusing, I sometimes switch it to check if it was off (then : okay, it was…). Why keeping a bit of light here ? Could it be possible to turn it off completely ?
Here are the B LED which should be off, and the massive white C LED dimmed with tape :
I’m reporting it and saving on the requests.
P.S.: quite of a “MacGyver” light tech you got haha
