Description
Using this pedal board shaggy 3 loop 1 - MOD Audio the Dwarf hung after recording a single track on the first looper and trying to record a second track on the second looper. Here is a video of the Dwarf being hung: https://youtu.be/LwJry6oL-uc . It has happened a couple of times, the first I had 5 or 6 loops running on all 3 loopers, one or two on each, and I was trying to switch between switch banks. The second time, as you see here, I had just one loop running on the first bank and I was in the process of changing routes when it hung. CPU usage was around 25%, I don’t know what RAM was like.
How to reproduce
- Use the pedal board and it might hang, although it might not - I’ve used it many times with no hang.
Expected/suggested solution
Either knowing what causes the issue so I can avoid it, or sorting so it doesn’t happen!
Additional information
Open the controller menu (hold left knob down), navigate to Info > Versions and write down here the versions.
- release: V1.10.1.2234
- controller: MDW01P01-00059
- Windows
- Windows 10, MS Edge.
