Dwarf footswitches sending midi cc toggle
Is there an option to use the 3 dwarf footswitches to send out midi cc toggle ?
I want to use these to control eg the bypass function of my L6 HX FX and maybe turn on/off some individual FX in the same unit
The 3 no, since the footswitch A is for pagination. But the footswitch B and C you can.
Simply activate the Virtual MIDI loopback port on the MIDI settings of the WebGUI (latest OS version on device is required), load a couple of Mindi plugins and assign them to the footswitches. I believe that this way it will work.
