Dwarf: Cannot change snapshot while
WebGUI: Cannot change snapshot while addressed to hardware.
What does this mean and how can this be fixed.
Thanks in advance for explanation
Can you give a bit more info?
Where are you seeing this and what are you trying to perform when it appears?
Thanks for reply
It was displayed on the WebGUI (top right) when I wanted to rename a snapshot. An entry was not possible with any snapshot that had already been created.
There seemed to be a connection with the current pedalboard, because with all others this message never was displayed.
In the meantime, I deleted this pedalboard and created a new one.
I think that if this error message is not known, the cause can no longer be determined.
You’re welcome :slight_smile:
Indeed. Yet, it would be nice to understand what was happening.
@falkTX do you have any idea when this message is triggered?
If the snapshots are addressed to the device, renaming them can cause conflicts, so we disable that.
Same thing for removing too.
Does that mean - If you want to add new snapshots after assigning them to a ModDuo Button/Knob, that you have to rebuild the whole pedalboard ?
You cant unassign the snapshots from the mod duo ?
Hello @Sharry and @Richard_Torry ,
I might be totally wrong chiming in here, but I think the proper way is
to un-assign the preset or snapshot list from the addressed knob or button on your device,
then rename or delete list entries and
then re-assign it to the knob or button of your choice.
Addressed to the device? Where else would they be addressed to?
And: how do you rename a snapshot?
