Hi, my new-used Duo X has started resetting itself consistently. It takes like 20 minutes and then it will reset itself 3 or 4 times in the span of the next few minutes, at which point I’ve been turning it off… I’m thinking of doing a factory reset after a backup, although I have so few pedalboards on this that if I lost everything but the plugin licenses I’d be fine with it. I’m using a lot of beta plugins but it does seem weird-- is this expected behavior with beta plugins? haven’t had problems quite like this on the Dwarf, really hoping I can figure it out! Any suggestions would be really welcome. Current pedalboard for reference:
