yep, limited edition
is there any possible workaround for this?
we removed the workaround, so the proper way would be to add it back in I guessâŚ
can you please confirm if the 1.11 release from Releases - MOD Wiki still works without lock ups for you?
         I will try it and let you know if it helped
just tested 1.11
with peak meters turned off I didnât get any freezes or any other problems.
so this is a peak meter problem.
it would be super nice if you can include peak meter disable flag in next firmware update)
and btw, maybe this is fixable without workaround (with peak meters working)? or is this a pure hardware bug of this limited edition batch?
