Hi !
Unfortunately, since I’ve made the upgrade :
- No sound at all when I load any of my previous pedal board (output leds do not flash)
- No new audio wire connection allowed to the output : when I pull a new wire to the output, the output can’t catch it.
- No new pedal board possible…
what works :
- bypass 1 and 2
- wire connection to plugins inputs (sound and midi from hardware inputs are received)
- wire connections between plugins
Hope you can do something to help…
falkTX
#2
that seems like a caching issue…
so you can try in your browser “private mode” as a test, or simply a different browser.
but you are running the old/legacy kernel, would be great to update for the new and better one.
See https://wiki.moddevices.com/wiki/Troubleshooting_Reinstall_Duo for instructions.
this link explains the situation https://www.moddevices.com/blog/the-mod-duo-is-still-evolving
Many thanks, I’m going to try this
