Dual MDX
Is anybody using two (or more) Mod Duo X?
If you are, how are you using them?
What are the benefits?
Thanks
Would it be possible to connect them via controllchain to controll each other?
No, ControlChain needs a main head node (the DuoX) and the rest of the devices sync to this. So far as I know you cannot turn a MOD unit itself into the client node.
You could connect one device as midi client to the other using the usb-host port or using a midi cable.
As @dreamer said, that is not possible.
