Drobilla - Exampler
This is an example plugin that we worked a little bit on to make it more usable as real plugin. (adding loading of non-mono files and resampling, plus fixing a few bugs)
It loads a sample and plays it on every received note, without changing pitch.
You can find it under Generators. Requires v1.10 installed on your unit.
Upload of new audio samples is done through the file manager screen.
