I know this is a long shot but is there any way of getting the Cardinal plugin host module working. Most module seem to work fine on the Duo X except that one.
Naturally I understand it is a tricky one!
That would be a big no.
If you want to route audio to other MOD plugins then use some of the extra i/o for that ![]()
Not sure what you mean here?
You mean the Carla and Ildaeil modules, yes? These can host LV2 plugins, like the ones we have inside MOD.
If you want to route audio to LV2 plugins, you can use any of the additional audio i/o in Cardinal to go to these plugins running inside MOD.
Aka: you donāt need the plugin host modules in Cardinal.
I mean using VSTs which Ildaeil can also load in Cardinal Desktop - this doesnāt seem to work when trying to run these on the Mod X.
Guess itās a compatibility issue and cannot port VSTās over to the MOD X architecture? I did say it was a long shot!
Theoretically it could work on desktop, but the UI/UX would not be good and indeed it would be impossible to use on any of the MOD devices.
The UI isnāt an issue, Iād want to use preset FX so no need to edit them on the device.
When you say ādesktopā - do you mean Cardinal? It works fine there with VSTās.
Guessing that cannot be transferred to the MOD X due to the FX a not being in the right format?
I mean mod-desktop as that is running on your computer, but lets not digress: this is not going to happen
On MOD Cardinal is not a plugin-host, these plugins you want to use will never run on a MOD device since they are built for your desktop machine.
Yeah, had a feeling that might be the case.
I havenāt time to explore it by myselft, but @falkTX is it possible to have two instances of cardinal listening on different ports on MOD so i can send different patches to them from my PC ?
Hi! Enjoying the small updates on Cardinal latest version 25.06. When will the Mod Audio plugin (s) be updated? Curious to see if I would be able to run Orca`s Heart (and Elements) on my DuoX. Love this Combination and I have the feeling the lack of GUI and precise controls will work well with this somewhat unpredictable sequencer.
It is updated now to 26.01, which also fixes the crash when connecting the OSC remote from the PC side.
Make sure to update Cardinal on both the MOD device and your PC as well, mis-matching versions will create undefined behaviour.
The big news here for me is that I created a random (glitchy) drums generator on Cardinal using modules from Wasted Audio like the HiHat, the CR78 or the Snare-n and wanted to port it to run on the MOD.
Before, that was not possible; with this new version, that works like a charm.
PS.: I wanted to give some polishing to this patch, but I may share it around ![]()
