A test of MIDI data sent through DIN-MIDI port. This setup uses a couple of MIDI channels for different sounds within the same port. Project file can be found at http://download.linuxaudio.org/kxstudio/tmp/midi-mod-test.los, made with https://github.com/falkTX/los/
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com//pedalboards/5964b10c2564d404a5d7c161
