Digital IO
While I wait for my Tier 3 Dwarf to arrive I have been dreaming about what I would do if I was designing a DSP audio appliance from scratch.
The most obvious application for me is real-time processing for low-latency tracking to a DAW.
One of my biggest headaches is having to overdub guitar through an amp simulator into an already-busy session with lots of tracks and effects.
Tracking guitar in this scenario often requires disabling reverbs or freezing tracks or bouncing the session down and overdubbing to that because otherwise the CPU is overburdened and simply cannot handle tracking cleanly at low buffer sizes.
Having an external DSP box to run the amp sim(s) would shift the burden of real-time processing away from the CPU and allow it to focus on running the session.
The Dwarf is almost the ideal box for this but not quite because it lacks digital IO. Analog IO inevitably means more latency added at the AD/DA stages. Also it has only two outputs which means that if I want to record a stereo rig I cannot simultaneously record the clean guitar signal.
I’d love the next version of the Dwarf to have ADAT/SPDIF lightpipe and/or AVB. In my mind this would be the ultimate standalone audio DSP for tracking.
Why would the USB audio feature not work for this?
Well, as an aside, I didn’t realize that the Dwarf could function as a USB audio interface. (Can it?)
But this is irrelevant. The real reason to use digital audio is that many of us in the studio have organized our workflows around a primary audio interface which is usually an integral part of our setups. Using the USB audio on the Dwarf would disrupt this workflow and defeat the purpose of having a high-end interface in the first place.
It’s entirely unreasonable to expect someone entrenched in his/her workflow to interrupt a session to switch from, say, an RME UFX II with it’s exceptionally reliable and performant drivers to some generic interface with class-compliant drivers. Especially if the session relies heavily on the hardware and software routing capabilities of the UFX II.
Using the USB audio on the Dwarf would defeat the purpose of having a high-end interface. The solution is to route digital audio out of the interface to an external device and back in again, latency-free.
That already exists in the MOD DuoX. Maybe the DuoX would fit better your needs.
Not yet, but that is planned.
Looks like the Duo X has only SPDIF outputs, not inputs.
In any case I already paid for the Dwarf :grin:.
That’s promising!
That’s correct
The idea is to have a completely digital signal path; input to output.
Could a Arduino Shield add numeric IO with some (made for RaspberryPi) card like this on ?
It’ll be way easier to get USB audio interfaces working. Then you just need to plug in an interface with ADAT or AES ports.
Blockquote
Dear Jon, will it be possible in the future to connect a sound card to the Mod Dwarf via USB, so as to be able to increase the number of inputs and outputs?
For example with a plugin that can see the digital inputs and outputs and connect it with the effects chain. This would open up new usage possibilities for the Dwarf!
That is something that has been discussed quite a lot. Possible it is and there are some users that even successfully implemented it, yet, there are some flaws. Check it on this thread:
I personally like this idea for the all platform. But I’m not sure if it would even be possible to be super reliable, compatible with all soundcards, etc. etc.
Thank you Jon! I have read the thread, it sounds promising!
Sorry guys, didn’t get if it would it be theoretically possible to connect two mods via usb/cc port adding minimum latency.
Control Chain is not for audio signals, but for Control signals :slight_smile:
Also you cannot connect two MOD units over the CC connection, only CC-devices can be linked using this.
Thanks but I was thinking about using CC eth port to send digital audio over UDP or other realtime protocols. The idea is to distribute signal processing stuff over multiple devices when SPDIF it’s not available.
“CC eth port” is not ethernet, it’s Control Chain. You will not get any networking done over this port.
I’m not strictly talking about eth and networking. I mean use the cc physical connector to tx/rx audio by a dedicated protocol.
Ah I see, but this would require to override however these pins are currently configured. I’m not sure if you can get suitable transfer rates out of this either.
But sounds like an interesting “hack” none the less.
I see there’s an I/O expansion arduino shield with I2C port. I’m wondering if it would be supported by CC.
What do you mean with “supported by CC”?
The Control Chain doesn’t have any “support” for specific hardware, it’s just a protocol to transfer data over.
