Getting this when I try to deploy from the shell:
tar cz bolliedelayxt.lv2 | base64 | curl -F ‘package=@-’ http://192.168.51.1/sdk/install
500: Internal Server Error500: Internal Server ErrorGetting this when I try to deploy from the shell:
500: Internal Server Error500: Internal Server ErrorI have a plugin in progress but haven’t deployed yet. I’ll check back on my system to confirm.
@Bollie yes, it still posible. I believe it’s a bug in the curl version 7.56.0. I have this version on my machine and it outputs the same error. Using the version 7.56.1 it works perfectly.
Ah, cool, thank you! Just received said version via pacman on Arch Linux and will give it a try later tonight.
Thank you!
