Delete Factory preset
Hi everyboby.
Is there a way to delete factory preset of plugin because I don’t want them in the preset list on my Mod Duo X screen. Some of them are horrible or useless so I could be nice not to have them.
Thanks
Hi, thats quite easy. Just click on the second button on the left bottom of the web interface to reach the pedalboard library and the press the delet button on the top right of the patch you want to delete.
https://wiki.moddevices.com/wiki/MOD_Web_GUI_User_Guide#Saving_a_pedalboard
Thanks for your help but I guess you don’t understand my question.
I want to delete factory preset in plugin preset list and just keep user preset.
It is not possible at the moment, but something we have in the plans for very soon.
Very good. Would it also be possible to move presets?
That’s planned, but you will still need to wait a bit.
Bumping this thread. Has there been any development on this issue?
Since some plugins have 10+ factory presets, this would be such a time saver if it would be possible to delete factory presets in a plugin.
Or even better - select which presets you want to assign. Would that be possible?
If I understand well your request, there were indeed updates.
I believe since the 1.13 you have the factory presets separated from the user presets.
nah that is not a thing yet.
we separated user vs “factory” pedalboards though, that was the change in 1.13 for the Dwarf.
My request was about the plugin preset, not the pedalboard preset. Some plugin preset are not usuable for me and it would be much clear when using the dwarf or duo X screen to see only my preset or to choose wich factory preset I want to keep.
To be more clear about my request. Factory Plugin preset and user plugin preset are separated in the editor and that’s fine. But on the screen device all preset are mixed together.
Sorry for my misusage of vocabulary (on purpose).
Aren’t you @Oskar_Molander calling “presets” to the pedalboards? Or are you talking about the plugin presets?
Gotcha! So you are talking on a device level and not WebGUI
I’m talking about factory presets within plugins. Let’s take the Gaffa Delay for example: I have made 3 different user presets that I want to be able to switch between fairly easily. The Gaffa Delay has 8 factory presets by default. Since the only way to assign presets to a knob on my Dwarf is to use the ASSIGN ALL-button - ALL the presets gets assigned. So now instead of having to scroll through my 3 user presets, I have to scroll through 11 presets in total, where 8 of them are, in this case, useless to me.
The feature I’m asking about is the ability to be able to choose which plugin presets (factory and user) that you would like to assign. Or the ability to delete factory presets within a plugin. Or the option to choose “assign user presets only”.
If you are looking for a “workaround” solution, based on my experience (try at you own risk) you can ssh in the device, navigate to the folder of the plugin of your interest and delete the ttl files related to the factory presets you want to get rid of (each preset is stored in a dedicated ttl file).
