Is there any way to have CV control a pedal? I would like to press one footswitch and have several pedals use a footswitch at once. On the SooperLooper I can control play and record with CV, they are click switched, but not reset which is a foot switch - any way of doing it?
yes, should be possible
Yet it isn’t - if I go to the control option for a pedal then the CV option isn’t there as it is for switches or rotary knobs.
Sorry I don’t follow, can you show us with some screenshots perhaps?
You want to turn these pedals on/off simultaneously?
What I just did in a quick test:
Control to CV (set to >5) -> Switchbox (name one of the outputs) -> select the name as CV-source on the on/off switch of your pedals.
Then have the channel selector on the Switchbox respond to a device button.
(there are probably other ways to also do this)
[Edit: aaaaah, I see now. Indeed these “footswitches” in the options (checking with SooperLooper) do not have a CV setting … hmmm at a loss here then, sorry :#
These are momentary switches, so I can see how controlling them from CV would be tricky to implement]
It really seems that you found a plugin without the CV ins or outs
So, in overall @dreamer suggestion works, but it doesn’t for the SooperLooper
Damn. lt works for the record and play, just not the other ones that I need!
Thanks for sharing it
