It would be super useful if plug-ins such as this one were allowed to be assigned to knobs. Having a knob that selects A or B is intuitive. You can’t assign the switch to CV either, so work arounds must be used, and it’s a little nuts that such a simple switch plug-in can’t be assigned to a knob. With a 3 way switch I totally get it, but A or B - would be nice.
For those looking to do something with only 2 static values, and not switching between variable CV signals - you can set a basic CV block with one, and then use the attenuator booster to add, or subtract from that amount, and that plug-in can be turned on/off with a knob.
For example I often have a delay where I want to choose between 20% or 50% feedback, (or something similar) - I can use the attenuator booster to achieve this.
nice solution, @S_Righteous !
just for future clarity: you mean the “Attenuverter Booster”, right? ![]()
Indeed I did - but couldn’t read the fine print! ![]()
