CS Chorus 1 - MOD Devices
David Robillard
Fomp is an LV2 port of the MCP, VCO, FIL, and WAH plugins by Fons Adriaensen. Based on a CSound orchestra file by Sean Costello. There are two low frequency oscillators, each having three outputs that are 120 degrees apart in phase. The summed outputs modulate three delay lines. Make sure the static delay (first parameter) is at least equal to the sum of the two modulation depths.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2Ryb2JpbGxhLm5ldC9wbHVnaW5zL2ZvbXAvY3NfY2hvcnVzMQ==
