CrossOver 2 - MOD Devices
MOD Team
This plugin receives an input signal and outputs 2 filtered signals. First one is filtered with a low pass filter (LPF) and the second, with a high pass filter (HPF), both cutoff frequencies are determined by "Freq" parameter. "Order" indicates filter's orders (or how fast frequencies above (in HPF) or below (in LPF) the cutoff frequency will decay. Higher the order, faster the decay) ."Gain 1" and "Gain 2" controls the gains of both outputs respectively.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL21vZGRldmljZXMuY29tL3BsdWdpbnMvbW9kLWRldmVsL0Nyb3NzT3ZlcjI=
A fun use of this is to run your instrument to two different effect lines. A simple example is the delay effect on the bass side is set to 60 and the high side is set to 120 triplets.
Or Fuzz on low end and Overdrive on top
