I’m not sure now if that might not already work (if so, I haven’t found it yet). It would be great if you could copy a plgu-in with all its settings and paste it into another pedalboard.
The solution is to save a preset of settings of desired plugin - if you use this same plugin in next pedalboard you can use the preset since saved presets can be used accrosed all pedalboards and are saved in the device. It is really great feature.
