Hello, excuse me.
I, too, am a fan of Amp1.
I can’t get the CC output in Dwarf to work, PG has no problem. (I am able to use Midi Learn in Amp1.)
I am sending directly to midi out via CC in mindi, but it doesn’t work.
Is there any way to do this?
Please, could you elaborate better your problem? Can you explain what are you trying to do, how things are connected, what hardware are you using, what are you expecting to happen? Don’t assume we all know what Amp1 or PG mean.
My apologies.
I was controlling a floor type amp called Bluguitar Amp1 via MIDI from a dwarf.
It is possible to MIDI learn with a PC. (Preset switching).
I can fine tune the tone with CC, but the CC signal does not work.
It is connected to Dwarf’s MIDI OUT with a cable and returned to Amp1 with a dedicated MIDI interface.
The signal is sent by the infamous mindi.
Thank you for your suggestion.
Sorry for my poor English.
Of course.
I am using an early model called the Silver Edition.
The one sold today is called the Mercury Edition.
CC 60 Boost on/off
CC 50 Reverb on/off
This command was not reflected in my Silver Edition.
Power Soak.
As for the 2nd gain, it was reflected in mindi’s cc signal with no problem.
