Control Switch Plugins with "Control to CV" Plugin
Is it possible to make the switch plugins controllable with the “Control to CV” plugin?
A bit more precise my question: Is it possible to make the MIDI/Audio SwitchBox controllable via CV. With this one could realize (several) routings (automated).
yes? is this not working already?
No.
hmm I guess that would be because it is a list.
in lv2, list-type parameters can use any value, it does not have to be sequential. so a list can be 0, 1, 4, 16, 999, 32767. how can a linear CV control properly map to these?
we can make an exception for lists that have linear + integer values.
that should make these work then.
will add this as a ticket for myself, thanks.
any progress on this?
i do notice that the Toggleswitch already has CV implemented as a control option. are the 4 switches in Toggleswitch not the same type of control as the various Switchboxes?
seems strange, since both plugins function as a selector between 2 options.
It’s still on the backlog. We have been super overwhelmed with work with the release of the Dwarf (and also some restrictions and limitations), so this kind of things are taking a bit longer. But we didn’t forgot them.
