Hi there! This is probably to @ricardocrudo as the author of cc-arduino-lib, or whoever can help me out. Is it my poor c++ skills (they really are poor), or I’m getting an impression that not all the control chain protocol (as described here) is implemented in the library?
A more specific question: what combination of an actuator config parameters shall I use to replicate the behaviour of the MOD Dwarf’s (B) and (C) buttons of scrolling up and down through the list of the snapshots of a pedalboard?
I can only implement the very basic on/off switch, following the examples from the library, but the documentation is rather scarce to venture beyond the examples.
Hi @TheRedOne, as far as I’m aware, all of the functions that are described on that page are in the library. There are even some new properties we still need to document . What parts are you referring too?
regarding switching pedalboards that is not possible at the moment, as the configuration of ControlChain devices are saved at the pedalboard level, making this rather tricky.
Switching snapshots should be possible though! you can do this in the webui under the snapshots “load/manage” button and then assigning it to the ControlChain device. As long as the Arduino device is configured to allow for lists (by adding CC_MODE_OPTIONS to the supported modes), it should show up there!
Thanks, @Jan, for your reply. I have tried CC_MODE_OPTIONS, but no luck so far. Specifically, I don’t get how to implement a button scrolling the list up. Can you share a bit of a code for, say, two footswitches that would scroll through the list up and down? Or at least show me a direction for further diggin’ by myself?
I’ll experiment more tonight, and post my workflow and findings here.
When you say “all of the functions that are described on that page are in the library”, are you referring to this library? 'Cos that’s what I’m using, and it seems that this library uses an outdated version of cc-slave library. E.g. compare the snippets of /cc-master/blob/master/lib/src/assignment.h and /src/assignment.h from the cc-slave that cc-arduino-lib uses.
Ok, I think I get it, so the ControlChain Arduino library is essentially a wrapper class for the cc-slave protocol, and I need to keep cc-slave sources up-to-date, and fool around with the wrapper class however I want.
right so for an example of how lists work, I guess the best place to look is at is at the MOD Footswitch firmware, but how the list incremented / dectremented is actually handled by cc-slave here everytime a button event is detected. (whether it goes up or down can be set with the CC_MODE_REVERSE property)
yes, sadly thats the case. We where developing an update for the ControlChain library, with the intention to update the Arduino library right after. However due to some delays we split the update in several parts and did not manage to update the Arduino library (yet), while the MOD Footswitch is already running a newer version of cc-slave.
so you could also say that both the wiki and the Arduino lib are outdated, but at least they are in sync
The arduino board is connected to my reference Nano Pi NEO2 based board and by doing
export LIBCONTROLCHAIN_DEBUG=2
controlchaind /dev/ttyUSB0 -f
[cc-lib] control chain started (port: /dev/ttyUSB0, baud rate: 115200)
even by resetting the board I see no output at all. After reading this thread, I’ve inspected control_chain.h in cc-master and the one present in cc-arduino-lib, I can see cc-master is using
so can you confirm again that arduino-cc-lib is not usable at the moment? I would just open an issue to github repo then with this information. I think the problem is updating arduino-cc-lib to the new protocol version, can you also confirm that? Thanks
The protocol should be backwards compatible, we have just did not find the time to update the Arduino lib too.
I’m not sure about the Nano Pi to be honest, as we never tested that one.
What I can confirm is that the cc-arduino-lib is working fine here on my uno and due, with IDE version 1.8.3.
Not saying this doesn’t need updating, and we are planning that after the next protocol release
