Control Chain / Footswitch: "Sticky" assignment across devices?
Hey folks,
I’m thinking about buying a second used Control Chain footswitch, so I can leave one in the rehearsal room. I’m wondering how button assignment behaves. Is it specific to the single device or will any footswitch of the same type at the same position in the chain have the same controls assigned?
Meaning: If I assign buttons at home to footswitch A and then take the Dwarf to rehearsal and only connect footswitch B - will the assignment be the same or will it be empty?
Thanks and best regards
Dennis
It should work exactly like the one that you had connected before, if I don’t mistake.
Meaning: You make the assignments with one footswitch, then you go and you have the same chain but with a similar footswitch, so it should take it as the same.
Again, I didn’t test it myself, but I believe that will be the behaviour.
