Hi MOD Team
The new Arduino-Shild is awesome!
Now that i managed to do my first ArduinoShild tests, Iโm thinking about some future projects.
What I need to know are the electrical specifications of the ControlChain port.
Especially the amount to current the MOD is able to supply via the CC-Port would be nice to know.
Thanks in advance
The power supply is shared with devices connected to the USB as well, which means the power available for Control Chain devices depends also if you have something connected to the USB. You can assume you have 12W available for both, Control Chain + USB. The voltage in the Control Chain connector is 12V.
Ok!
That should be more than enough for my needs!
Thank you a lot for the fast answer!
